Removing burned-in text
Dominic Witherow
on Aug 16, 2010 at 6:53:48 pm
I have a VHS of a friend's wedding with timecode burned in. Can anyone suggest a way to remove the text? The result does not have to be perfect, just watcheable. I have been trying to do it in Shake, using masks and painting clone pixels, but it is just too much to do that way. I have also trialled The Foundry's wire removal plug-in, which is awesome, but would take my G5 2.7 Dual over a YEAR to render in full! So I turn to AE as it is just so darn clever! I am on CS3 at the moment, but expect to upgrade my entire system in the next few weeks and will soon be on CS5.
Any suggestions?
Thanks in advance. Dominic
Dave LaRonde
Re: Removing burned-in text
on Aug 16, 2010 at 7:02:01 pm
You could give this a shot:
http://library.creativecow.net/articles/drozda_jerzy/SimpleObjectRemoval.ph...
Dave LaRonde
Sr. Promotion Producer
Dave Johnson
on Aug 16, 2010 at 7:11:57 pm
Unfortunately, there's really no way to do this since there are plenty of ways to remove a timecode window (masking, blurring, etc.), but there's still the much more significant problem of how to fill the space it leaves ... it's not as though there's video information behind that black timecode box that just needs to be restored somehow ... there's nothing there so there's nothing to fill it with unless the scene is so uncomplicated that it would be passable to essentially paste another region of the screen over or paint over the hole.
Dave LaRonde
on Aug 16, 2010 at 7:31:02 pm
The time/date stamp on a VHS tape isn't a time code window burn. And if there's any kind of transparency, it could be done. It would take a ton of work, and the results would be much less than satisfactory, but it could possibly be done. Here's another tutorial:
http://podcasts.creativecow.net/after-effects-tutorials-podcast/watermark-r...
The tricky part: isolating the time/date stamp. If you figure that out, you stand a fighting chance.
Dave LaRonde
Dave Johnson
on Aug 16, 2010 at 8:40:42 pm
Good point, Dave ... I should've read more thoroughly ... guess I missed the "VHS" part so I was thinking of a window burn with the big black box.
Chris Wright
on Aug 16, 2010 at 9:19:35 pm
I know logoaway works almost perfectly.
http://www.videohelp.com/tools/Virtualdub_Logoaway_filter
http://technicolorsoftware.hostzi.com/
Dominic Witherow
on Aug 17, 2010 at 8:10:39 am
That sounds fantastic, but is there a version for Mac?
Thanks very much for the speedy replies everyone! I suspect I have a lot of work to do still ...
