CS5: Prores Output Lost
Mark Reese
on Aug 16, 2010 at 6:34:30 pm
I had CS4 installed on my MacPro (the same machine FCP is installed on) and when I installed CS5, I lost the ability to export prores files. Anyone have any advice? Thanks.
Dave LaRonde
Re: CS5: Prores Output Lost
on Aug 16, 2010 at 7:59:47 pm
If you really are exporting, try rendering using the Render Queue, and report back in.
Dave LaRonde
Sr. Promotion Producer
Mark Reese
on Aug 16, 2010 at 8:09:54 pm
Yeah, I'm using the Render Queue. Prores is not available there (only lossless) nor is it available to set as a default under Edit > Template Settings > Output Module.
Walter Soyka
on Aug 16, 2010 at 8:17:52 pm
[Mark Reese] "Prores is not available there (only lossless) nor is it available to set as a default under Edit > Template Settings > Output Module."
ProRes is not a default output module -- but you should be able to select it by editing an output module and choosing ProRes as the codec under Video Output > Format Options.
See Output modules and output module settings for more.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Mark Reese
on Aug 16, 2010 at 8:23:21 pm
I'm an idiot. Thanks. Reading comprehension is apparently a system requirement for CS5.
