CC Film Burn crashing After Effects
Justin Maloney
on Aug 14, 2010 at 12:03:58 am
Hello there, I'm having a very bizarre problem.
I've been making lower thirds for a television program I work on in After Effects. The graphic is very simple, its just a couple shape layers, some text, and an adjustment layer. The lower third animates itself away with CC Film Burn. Up until now, I've been able to crank out several lower thirds with no problem whatsoever. But the other day, when I try to render out some more, AE Crashes!
I painstakingly tried to trouble shoot the problem. I messed with memory and processing settings, disabled Open GL, and even tried lowering the final output resolution. The only thing that worked was removing the CC Film Burn effect from the adjustment layer.
I've since managed to work around the problem, but I'm terribly confused as to why it stopped working all of a sudden in the first place. Does anybody have any ideas? Thanks in advance!
Todd Kopriva
Re: CC Film Burn crashing After Effects
on Aug 14, 2010 at 4:52:41 am
Version number? Operating system? Other details?
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Justin Maloney
on Aug 16, 2010 at 10:20:01 pm
Sorry for the late reply.
I'm using Windows 7 Professional
Intel(R) Core(TM) i7 CPU 930 @ 2.80 Ghz 2.80 GHz
6 gigs of ram
Adobe After Effects CS4 version 9.0
Dave LaRonde
on Aug 16, 2010 at 10:27:40 pm
With only 6GB RAM, you can't rally use AE's multiprocessing feature. If you have it on, turn it off and give the render another shot.
Dave LaRonde
Sr. Promotion Producer
