Moving paint brush
Mei Mei Yip
Moving paint brush
on Aug 13, 2010 at 6:38:37 am
I am new to After Effect CS5 and am looking forward to playing around and getting to use all its features. Unfortunately I have an urgent DVD home project to do.
I saw this effect on You Tube:
It's a white piece of paper and a hand with a paint brush paints on the paper. Instead of seeing paint you get to see a picture underneath. Cool.
But how do I go about doing this?
Any help would be most grateful.
Tudor "Ted" Jelescu
Re: Moving paint brush
on Aug 13, 2010 at 4:51:51 pm
Pretty much all you need is a bunch of paint strokes created in Illustrator (for example) that are revealed by animated masks. Make a black & white render of the animated strokes and then use that as a matted for the footage layer. Of course the animation needs to follow the brush as it moves- also you will position the strokes created in Illustrator to follow the brush movement ( you can also distort them with the mesh warp).
Tudor "Ted" Jelescu
Senior Compositor/VFX Artist
Bucharest, Romania
Jason Byfield
on Aug 14, 2010 at 12:07:51 am
I'm pretty sure that the brush strokes were actually captured in camera using black paint and then in AE the painting footage was layered above the revealed footage. By changing the transfer mode of the painting footage to "Screen", the footage underneath should reveal itself through the black.
© 2018 All Rights Reserved
