PhotoJPEG Banding in CS5 AE
Phil Bates
on Aug 12, 2010 at 10:46:31 pm
We typically output QT movies for our stock footage library using PhotoJPEG at 95% quality. Never had a problem...until now. CS5 is giving us fits with banding problems. Here is a comparison between the CS4 and CS5 output (you will have to look closely to see the banding, however, it is very obvious when viewing the HD image at 100%):
We see this problem with all PhotoJPEG quality settings including 100%. All projects are set at 16bit color. No differences in the output module settings. Any thoughts?
Kemalettin Sert
Re: PhotoJPEG Banding in CS5 AE
on Dec 3, 2011 at 3:26:11 am
did you solve this problem?
© 2018 All Rights Reserved
