Knoll Light Factory - Obscuration Layer
florian herweg
on Aug 11, 2010 at 9:09:29 am
hey.
I have a short question. I am using Knoll Light Factory with an obscuration layer in After Effects CS4. I just recognized, that everything works fine in the preview but when I'm rendering the Light Factory Effect is missing in the finished file.
Rendering without an obscuration layer works.
So am I doing something wrong? I've just seen a posting in creativecow that someone has the same problem but there was no solution - only not to work with obscuration layer. but this can't be a possibility?!?!
greez
flo
Dave LaRonde
Re: Knoll Light Factory - Obscuration Layer
on Aug 11, 2010 at 7:47:30 pm
[florian herweg] " I am using Knoll Light Factory with an obscuration layer in After Effects CS4... everything works fine in the preview but when I'm rendering the Light Factory Effect is missing in the finished file... am I doing something wrong?"
If you're using Open GL, either in Light Factory itself or in AE Preferences to accelerate rendering, turn it off. Quite often in AE, Open GL simply does not work as well as advertised.
Dave LaRonde
Sr. Promotion Producer
