Same/linked keyframes for a layer style across multiple layers
Marty Hoedjes
on Aug 10, 2010 at 1:53:19 pm
Hey guys,
I've been trolling around the internet for an answer, but nothing seems to get it right. I got about 50 layer to which I assigned an Outer Glow effect. Now I want to change the opacity of this effect uniformly across all layers following a certain succesion of keyframes.
But whenever I alt-click on the stopwatch and link the opacity to the keyframes, it only works for the one layer (though I have them all selected).
Whenever I try to 'Copy Expression Only' and paste to all layers, the opacity changes over the entire layer, and I only want it to change for the Outer Glow.
What can I do?
Thank in advance,
Marty
Dan Ebberts
Re: Same/linked keyframes for a layer style across multiple layers
on Aug 10, 2010 at 3:21:11 pm
I just tried it, and Copy Expression Only works for me in your scenario. You have to have the property with the expression selected when you do the copy though - that's the only thing I can think of. After you do the copy, paste it into a text editor. It should look like this:
Adobe After Effects 8.0 Keyframe Data
Layer Styles Outer Glow Opacity
Expression Data
thisComp.layer("Layer 1").layerStyle.outerGlow.opacity
End of Expression Data
End of Keyframe Data
Dan
Marty Hoedjes
on Aug 10, 2010 at 3:27:06 pm
But do I paste it for 50 separate layers then? That seems kind of redundant.
Marty Hoedjes
on Aug 10, 2010 at 3:33:49 pm
Weirdly, it does seem to work OK now.
I don't know what I did wrong before, since the expression contains the information that the opcity is for Outer Glow.
