Multi Still From Timeline
thomas mcmurry
on Aug 8, 2010 at 9:42:36 pm
I have PSD (CS4) with over 200 layers I need to export each as jpeg to bring into iMovie (don't ask) to make a slideshow with funky transitions.
I can't find a way to export multi layers from photoshop and I thought I'd import into AE, make them all one second in duration in one timeline, and now I can't figure out how to export multi points in the timeline. I thought I did this ears ago in AE. IS this possible in AE?
Any other easy way to do this without exporting EACH layer individually from PS?
AE/PS CS4 / Mac
Andy George
Re: Multi Still From Timeline
on Aug 9, 2010 at 12:22:49 am
I use this script to do what your talking about
http://aescripts.com/rd-render-layers/
Set it to "layer in and out points" and it will render every selected layer in a composition to it's own file. You will need to set up a render template first so that the script can access your jpeg render settings.
-Andy George
Senior Editor
http://www.chiselindustries.com
Michael Szalapski
on Aug 9, 2010 at 1:43:13 pm
Always more than one way to skin a cat:
Select all of your layers and trim them to be one frame long. (Move the CTI one frame forward and press atl+] to trim)
Sequence your layers using the handy Sequence layers keyframe assistant
Then render your composition as a JPEG sequence.
- The Great Szalam
Adriano Moraes
on Aug 9, 2010 at 4:30:34 pm
Well I´m not a big fan of skining cats but here goes another way.
This time inside photoshop.
Open your documents and go to:
FILE>Scripts>Export Layers as Files
And there you go.
Cheers.
