Running out of workspace area - workflow to make everything fit
Alex Volkov
on Aug 4, 2010 at 4:53:50 pm
Hello
I am making a project where I'm explaining a particular subject visually, but now my whole area is filled up. I am rather new in AE, and I still haven't really figured out a way of, which workflow is best for this sort of thing. Should I expand my work area into a huge one, and let a single camera pan around into corresponding spots, should I convert all of my stuff (shapes, masks, texts) into a new precomp and let it pan around to show particular parts, or is there a whole another approach?
To rephrase my issue: I want a better overview of my objects in the workspace, because there will be alot of cammera zooming and panning, because I am making some animated mindmaps.
I appreciate all the help
Best Regards
Dave LaRonde
Re: Running out of workspace area - workflow to make everything fit
on Aug 4, 2010 at 5:04:24 pm
This sounds pretty complicated... what does your storyboard look like?
You DO have a storyboard for planning purposes, right?
Dave LaRonde
Sr. Promotion Producer
Alex Volkov
on Aug 4, 2010 at 5:08:10 pm
Hi, thanks for your fast reply :)
I'm usually using detailed storyboards for my projects, but this is a rather simple project, and the storyboard for this is a sketched version on a paper, with some notes on it.
Jeremy Allen
on Aug 4, 2010 at 9:55:31 pm
I guess it depends on wheter you are more comfortable animating a camera or moving a comp around.. Either way you would create a really big comp to lay out all your different parts. Then you could either animate a camera in that comp, or put the big comp into a smaller, final frame size comp and move the comp around to show the different parts.
Personally, I would probably go for animating the camera. That way you can still see the other parts at all times while working, and if you need to re-time the camera with certain animations, it's easier because it's all in one comp.
Hope this helps.. Others may have better methods.
8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.6
C4D 11.5
AE CS3
FCP 6.0.1
