Fx Factory and After effect crash
Maik Diederen
on Aug 3, 2010 at 5:09:47 pm
Dear members,
After i install FXfactory 2.1.3 i can uses the plugins in FCP. There a no problems.
When i open after effects after 3 seconds it crashes with a lot of threads.
When i uninstall FX Factory, after effects runs perfect. I don't need FX factory in After effects only in FCP.
I hope someone can solve this problem. I'm sorry for my bad englisch.
Kind regards, Maik
Walter Soyka
Re: Fx Factory and After effect crash
on Aug 3, 2010 at 5:59:48 pm
[Maik Diederen] "After i install FXfactory 2.1.3 i can uses the plugins in FCP. There a no problems.When i open after effects after 3 seconds it crashes with a lot of threads.
When i uninstall FX Factory, after effects runs perfect. I don't need FX factory in After effects only in FCP."
FxFactory 2.1.3 is outdated. The current release is 2.5. Upgrading might solve your problem.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Maik Diederen
on Aug 3, 2010 at 7:21:02 pm
I did and that didn't solve my problem. :(
Walter Soyka
on Aug 4, 2010 at 12:39:43 am
Something else is clearly wrong with your system if AE is crashing every time it tries to start FxFactory. Have you tried restoring AE's default preferences?
In a pinch, you could manually remove the FxFactory plugins, though this may not solve the underlying issue that's causing your crash. Look in Macintosh HD > Library > Application Support > Adobe > Common > Plug-ins > (pick your version of AE) > MediaCore, and you should find two files for FxFactory: FxFactory.plugin and ImporterFxFactory.bundle.
Walter Soyka
Maik Diederen
on Aug 5, 2010 at 8:51:49 am
Thank you Thank you Thank You,
I removed manual the plugins in after effects like you said. After effects runs again only when i activate AE
load16 plugins with the message: THE PLUGIN COULD NOT BE LOADED. Is there a way to erase these plugisns from AE ?
Thanks!!!!!
Regads, Maik
Walter Soyka
on Aug 5, 2010 at 2:25:05 pm
[Maik Diederen] "I removed manual the plugins in after effects like you said. After effects runs again only when i activate AE load16 plugins with the message: THE PLUGIN COULD NOT BE LOADED"
As I suggested earlier -- it may not be FxFactory that's causing the problem. Have you rebuilt the AE preferences?
Walter Soyka
Maik Diederen
on Aug 17, 2010 at 12:09:46 pm
I'm sorry for this late reply, i was on a holiday.
I did what you said en i rebuild the preferences in AE. The same problem is still there and AE loads 16 plugins from FX fac and tells me that they could not be loaded.
Regards, Maik
Michael Ryan
on Feb 14, 2013 at 5:53:06 am
I was having same problem, and your solution worked! Thanks!
