AE Layer Styles jagged edges
Stef Prein
on Aug 3, 2010 at 9:30:56 am
Hi!
For a project I used layer styles to add strokes and drop shadows to shapes. Some shapes come from Illustrator and some are shapes from AE. But most of the edges are kinda jagged. But for example not the edges of the circle in the lower left portion of the composition.
What could be the problem?
Thanks a lot in advance!
Stef Prein
student Image and Media Technology
Utrecht School of the Arts
The Netherlands
http://www.stefprein.com
Dave LaRonde
Re: AE Layer Styles jagged edges
on Aug 3, 2010 at 4:34:45 pm
Do you use the Collapse Transformations switch on your layers?
Dave LaRonde
Sr. Promotion Producer
Stef Prein
on Aug 3, 2010 at 4:56:01 pm
Hi Dave,
Yes Collapse Transformation is on by default. I can't even turn it off... I also found the solution: recreating the shapes seems to solve the issue. But I have no clue about the real source of the problem. To me it looks like there's is some render issue going on. I use CS4 by the way.
But the problem is kinda solved, at least I have a decent solution. So thanks a lot for your help!
Stef Prein
The Netherlands
