Text Plugin
matt mosher
Text Plugin
on Aug 3, 2010 at 3:19:20 am
I recently saw on the web a plugin that has a glowing animated text effect that will wrap the text around the entire wall top to bottom of a scene. Does anyone know of the plugin ? I can't remember where I saw it?
Matt
Kevin Camp
Re: Text Plugin
on Aug 3, 2010 at 3:19:32 pm
[matt mosher] "text effect that will wrap the text around the entire wall top to bottom of a scene."
are you talking about a 3d scene constructed in ae, or an image/footage? and do you only want to map it to a single wall, or will it wrap around something like 2 walls and a floor, like a projection of text into a room?
if you just needed to map text to a wall in an image/footage, then you could use something like corner pin, or make the text layer 3d and rotate and position it to match the perspective in the shot.
if you can create a depth map for the planes of the room, you could try the displacement map effect on a text layer.
if you want it to be more like a projection, then you can actually use the text layer and a light to project it into the scene. if you need to project it onto an image/footage then you could adapt andrew kramer's 3d projection technique. here's that totorial:
http://www.videocopilot.net/tutorial/3d_camera_projection/
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
matt mosher
Re: Text Plugin
on Aug 3, 2010 at 6:52:02 pm
I am looking to wrap it around the 2 or more walls and the floor if needed. With a projector type lighting effect i.e.- like the brinks home security effect that they have in there commercials. If you have seen those on TV.I don't have a link for them.
Dave LaRonde
Re: Text Plugin
on Aug 3, 2010 at 8:13:33 pm
Then you should check out the videocopilot tutorial Kevin mentions. It ought to work for you.
Dave LaRonde
Sr. Promotion Producer
Roland R. Kahlenberg
Re: Text Plugin
on Aug 5, 2010 at 2:21:06 am
As good as Andrew's training are, they can be confusing for some folks cos Andrew doesn't make it a point to explain the details.
Our very own Rick Gerard worked on an identical effect ages ago and his tutorial is much more in-depth and focuses on really teaching the topic very well.
http://library.creativecow.net/articles/gerard_rick/Projection_tut.php
HTH
Roland Kahlenberg
Sell your AEPs with broadcastGEMs' DVD series of templates. Click here for more
