Track matte causing a blurred footage
Michael Straub
on Aug 2, 2010 at 6:26:52 pm
I am currently creating a bitmap sequence for a broadcast graphics box(only supports bmps). After exporting them from AE I took them back in to test and noticed that the end result is blurred and the edges are cut off.
Any suggestions?
Walter Soyka
Re: Track matte causing a blurred footage
on Aug 3, 2010 at 12:45:37 am
[Michael Straub] "I am currently creating a bitmap sequence for a broadcast graphics box(only supports bmps). After exporting them from AE I took them back in to test and noticed that the end result is blurred and the edges are cut off."
So you render to a BMP sequence in AE, and then when you test it on the playback device, it doesn't look right?
What is the playback device, and have you met its specs exactly?
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Michael Straub
on Aug 3, 2010 at 1:22:09 pm
As of now, to appease those who need to see it before it goes to air (and because the station that broadcasts our signal is on the other side of town) it's being checking in After Effects.
I added an image of the result
