Wigglerama anchor point
Liam Stirland
on Aug 2, 2010 at 8:36:25 am
Having trouble with wigglerama, i've used the effect in the past and had no probs, Today ive added the effect to a text layer and although the text layer's anchor point is in the center, the effect seems to use the corner of the text lay to scale and rotate from, i can't see how to adjust it, surely it should use the layer anchor point?? im very confused.
Dave LaRonde
Re: Wigglerama anchor point
on Aug 2, 2010 at 3:24:40 pm
Your text layer may not be set up properly. Double-click on it, then look at the paragraph settings. They're probably set to right or left justified. Change it to centered. Alternatively, you could always just change the Anchor Point settings for the layer.
Dave LaRonde
Sr. Promotion Producer
