Expanding effect over the Canvas Size
Sascha Engel
on Jul 30, 2010 at 3:18:34 pm
Hi Everybody,
as you can see on the screen pic, I have an effect - lens blur - attached to an adjustment layer, which is itself attached again to the tracking data of a Null Layer.
When the Adjustment layer moves to far in, I can see the cut of the lens flare effect, for it is attached to the Canvas size of the Adjustment layer.
How can I expand it over the the edges of the Adjustment layer, so it fills the whole screen?
Sascha
Dave Johnson
Re: Expanding effect over the Canvas Size
on Jul 30, 2010 at 4:29:56 pm
If you're going to move an adjustment layer, it needs to be bigger than the comp it's in.
Dave LaRonde
on Jul 30, 2010 at 4:33:47 pm
The first thing I'd try would be the Grow Bounds effect. You may have to put it in a specific spot in the order of effects.... perhaps at the top. If it doesn't work, you might be able to make the adjustment layer bigger.
Dave LaRonde
Sr. Promotion Producer
Sascha Engel
on Jul 30, 2010 at 5:05:47 pm
Grow Bounds did not work. Had the opposite effect. Will try bigger adjustment layer.
Thanx!
