setting y to be z?
mark pigott
setting y to be z?
on Jul 27, 2010 at 7:22:43 pm
In 3ds max, what is y is z in after effects and and z is y.
As I would like to consolidate to have y as the screen-in and out parameter and z as the up-down parameter, I was wondering if there
is a swap y-z feature in ae?
thanks
Dave LaRonde
Re: setting y to be z?
on Jul 27, 2010 at 7:36:41 pm
[mark pigott] "In 3ds max, what is y is z in after effects and and z is y."
I'm not going to question that statement -- I don't use 3DSMax. But that's just weird.
Although I have no direct experience, AE has used 3DSMax files successfully for years. Has something broken when going between the two applications?
Dave LaRonde
Sr. Promotion Producer
mark pigott
on Jul 27, 2010 at 7:45:33 pm
It's not that either application is broken; it is the fact that
3ds Max used the right-handed rule for xyz, whilst adobe after effects
and apple motion use the left-handed rule.
It means as I happily animate in 3ds Max, I know up and down are z.
Whilst when I switch to 3d after effects I have to mentally know that
y is the up-down co-ordinates.
Its a matter of convenience, that's all.
