Combining several paths from Illustrator to one AE mask
Mike Sullivan
on Jul 26, 2010 at 5:26:29 pm
I am not very Illustrator savvy. How can I take a few different paths from Illustrator and convert them into one mask in AE?
keith mcgregor
Re: Combining several paths from Illustrator to one AE mask
on Jul 26, 2010 at 7:14:11 pm
Sorry, it really doesn't work that way, when you select all and copy, then tab over to AE and paste, it brings all the paths and makes them separate because it sees all the paths, some are intersecting and some are probably not closed. You'd have to make it one path in Illus and then it will see one path in AE. Is there anyway you can make it one path?
-Keith
Reality? What did you make it?
Dave LaRonde
on Jul 26, 2010 at 9:39:46 pm
Depending on what you're doing, you may not even NEED to make one mask. For example, you may be using the layer with all the illustrator paths as a track matte. I wouldn't think you would have to do anything to it.
Dave LaRonde
Sr. Promotion Producer
