Mask won't work
Matthieu Marcotte
Mask won't work
on Jul 20, 2010 at 11:47:44 pm
Hey guys,
When I try to mask put some elements it doesn't work. Could it be because I'm using particular or something? I've tried a variety pf things and nothing seems to help.
If you guys have any ideas of what I can do that would be great.
Matt
Brian Charles
Re: Mask won't work
on Jul 21, 2010 at 2:26:04 am
Precompose the particular layer.
Andy George
Re: Mask won't work
on Jul 21, 2010 at 2:40:24 am
Hi Matt,
We might need you to describe in greater detail what your trying to do and how your trying to do it, but Ill take a stab in the dark.
Your appling a mask to a solid with Particular on it. It does not work that way Im guessing because particular creates it's own 3D math inside the plugin and overlays that information on a 2D AE layer. Most of the "illusion of 3D" effects do not respect the typical render order rules.
There are other methods like obscuration and lumma mats that might be more appropriate for what your trying to do. What are you trying to do?
-Andy George
Senior Editor
http://www.chiselindustries.com
Matthieu Marcotte
Re: Mask won't work
on Jul 21, 2010 at 2:02:21 pm
Hey Andy,
I made some fake cigarettes cause none of my actor can actually smoke and I've added the smoke in post. Now when the cigarette goes in front of them or gets blocked by something I need to mask or hide where the particles are emitting from but still have them emit. I'll give a shot at what Brian says to do and see if that works.
Thanks for the speedy response =D
Matt
Andy George
Re: Mask won't work
on Jul 21, 2010 at 5:42:45 pm
I would probably approach this by duplicate my footage and masking the charector rather than the particles. Place the foreground elements on top of the particles in your stacking order.
The problem with precomposing particular layers is that you lose the connection between your particles and camera. This connection is necessary for accurate motion blur and depth of field. Probably not an issue with your comp but something to keep in mind.
-Andy George
Senior Editor
Matthieu Marcotte
Re: Mask won't work
on Jul 22, 2010 at 1:54:00 am
Hi guys,
I did what brian said and it worked. Can't believe that was all I had to do :\
Thanks for the help you guys,
Matt
