writing a simple script to set null object anchor point in the center?
Allison Sabelli
on Jul 18, 2010 at 6:21:51 pm
Hi everyone, I need some little help here, I'm very new to AE and scripting is unknown territory, however I'm learning by looking at other scripts and reading a lot. However I'm a little stuck here with the anchor point.
I'm trying to write a simple script that adds a null object to a scene and set its size and its anchor point right in the center, so far I got everything I need but the anchor point :\
here is what i got
var nw = 50;
var nh = 50;
var myNull = myComp.layers.addNull();
myNull.source.name = "My NUll";
myNull.source.width = nw; // getting this right :)
myNull.source.height = nh;
myNull.source.anchorPoint = ???; //I know should be an array for [x,y,z] but I get errors if i try.
myNull.threeDLayer = true;
I might be doing this all wrong, I don't know ahhaha but how do i set the anchor point to be in the center?.
Any help is very much appreciated, thanks
Andy George
Re: writing a simple script to set null object anchor point in the center?
on Jul 18, 2010 at 7:33:51 pm
Hi Allison,
Just FYI You might get a better response posting this over at the expressions forum.
-Andy George
Senior Editor
http://www.chiselindustries.com
Dave LaRonde
on Jul 19, 2010 at 2:57:16 pm
Actually, I don't know if messing with a null object's anchor point is necessary or desirable. It just takes a little getting used to -- it's always in the upper-left.
If you can give me an instance where you absolutely need to do it, I'll gladly change my tune.
Dave LaRonde
Sr. Promotion Producer
Darby Edelen
on Jul 19, 2010 at 8:07:56 pm
[Allison Sabelli] "myNull.source.anchorPoint = ???; //I know should be an array for [x,y,z] but I get errors if i try.
myNull.threeDLayer = true;"
I'm not familiar with scripting in AE, but I hope I know enough about general programming to help :)
I'd say you want to set the layer to be 3D before you attempt to set the anchor point to a 3D vector. A 2D null object may not allow for a 3rd component in the anchor point.
That's the only thing I can think of from a non-AE scripting specific perspective.
Darby Edelen
