Motion blur in nested comps - seeking a work-around
jim lefevre
on Jul 14, 2010 at 1:09:18 pm
I've got a project with 59 scenes/comps of differening lengths within it and having worked my way through the main body of work I've just found out that all of the comps have the wrong shutter angle/sampling (in composition settings/advanced).
Is there any way of being able to change all comps very simply or is it simply a case of me having just learned a lesson in thinking things through before creating lots of comps and just doing them all manually?
I was hoping that the motion blur could be controlled by my top-comp but thinking that through that would be rather irritating when you didn't need it...
Any thoughts would be appreciated!
jim
http://www.jimlefevre.com
jim lefevre
Re: Motion blur in nested comps - seeking a work-around
on Jul 14, 2010 at 1:30:49 pm
Aha! Having done a bit of deeper digging on the posts I've discovered an answer so thought I'd put it up here...
- Adjustment layer over all comps in the main compostion
- Effect - Time>CC Force Motion Blur
Hooray!
(and many thanks to a variety of people from the other posts for pointing the way)
jim lefevre
on Jul 14, 2010 at 1:37:23 pm
hmmm... although saying that it does effect it in a very different way than the comp-specific motion blur... poo
Roland R. Kahlenberg
on Jul 14, 2010 at 2:09:42 pm
The Transform effect has Motion Blur settings. Not too sure how you're setup but perhaps you can save it as a Preset.
HTH
RoRK
Sell your AEPs with broadcastGEMs' DVD series of templates. Click here for more
cowcowcowcowcow
Walter Soyka
on Jul 14, 2010 at 2:59:37 pm
[jim lefevre] "I've got a project with 59 scenes/comps of differening lengths within it and having worked my way through the main body of work I've just found out that all of the comps have the wrong shutter angle/sampling (in composition settings/advanced). Is there any way of being able to change all comps very simply or is it simply a case of me having just learned a lesson in thinking things through before creating lots of comps and just doing them all manually? "
The Selected_Comps_Changer.jsx script, courtesy of the brilliant Christopher Green, will get you halfway there. Select all the comps you want to change, run the script, and enter in the new shutter angle and phase.
http://www.crgreen.com/aescripts/
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
jim lefevre
on Jul 14, 2010 at 3:13:08 pm
Oh Crikey! That totally rocks!
I'm going to download and donate straight away! It's talented and generous people like Christopher Green that make the world go round so beautifully sometimes!
Thanks for the tip Walter.
on Jul 15, 2010 at 7:17:05 pm
Awesome find there Walter.
Cheers
RoRK
