Problems 2 compress
Chris Glazcier
Problems 2 compress
on Jul 12, 2010 at 9:36:52 pm
hi all,
i want to stream a video (made in after effects) on the internet.
what´s the best way to reach that aim? Quality should be as good as possible
i use:
- a mac book pro, 2,5 GHz Intel Core Duo, 4 GB 667 DDR2 SDRM.
- After effects cs3
- Quick time pro
I shot Footage with a DigiBeta 970 (progressive). After that i made a video and did some effects. I now want to upload this video on my server to make it streamable.
My Render Options were:
Format: Quicktime Movie (1024 x576)
Formatoption: NOT animation but Uncompressed - 10 bit 4:2:2
Video duration: 4 minutes.
Result: Redered File about 9.8 GB
First Problem: I want to play it with quicktime. quicktime does not run the video fluently.
Second Problem: How can i compress it the best way for webstream use?
i tried to export it as .flv (flash) but Quality was really bad.
Please help and tell me what is the best way to compress my file.
Thank you very much!!
Chris
Michael Szalapski
Re: Problems 2 compress
on Jul 13, 2010 at 1:07:46 pm
Rendering out of AE uncompressed is a good idea, you might consider using Quicktime with the PNG codec for smaller file sizes, but still lossless format. Then use a separate program such as Adobe Media Encoder. There are some great compression options there for broadcasting on the web such as Quicktime with H.264 compression or MPEG-4 compression.
While you COULD do the compression straight out of After Effects, Dave LaRonde explains why you shouldn't:
Dave's Stock Answer #3:
Don't use AE to compress files for final delivery. The various compressors are there only to make quick 'n dirty files showing a project's progress to producers, clients, the kids, etc. AE is incapable of doing multipass encoding, a crucial feature that greatly improves the image quality of H.264 and MPEG-type files in particular.
Render a high-quality file from AE, and use a different application to do the compression. Popular ones are Adobe Media Encoder, Sorenson Squeeze and Apple's Compressor, which comes bundled with Final Cut Suite. Even compressing in Quicktime Pro is better than compressing in AE.
Making good-looking compressed files is almost as much an art as it is a science. It is NOT straightforward at all. I recommend asking a few questions at the COW's Compression Techniques forum.
- The Great Szalam
Chris Glazcier
on Jul 14, 2010 at 8:50:01 pm
Hey Szalam!
Thank you very much for your answer. Will try this out!
I will tell how it worked :)
Greetz Chris
