Depth of field on camera not affecting particles in particular
Mitch Hardison
on Jul 6, 2010 at 1:11:58 am
My particles are not being affected by the depth of field on my camera. Even when I turn the blur level and aperture way up.
Walter Soyka
Re: Depth of field on camera not affecting particles in particular
on Jul 6, 2010 at 12:31:18 pm
Particle types "glow sphere" and "star" do not support depth of field. Also, in Particular's effect controls, Render Settings > Depth of Field should be set to "Camera Settings."
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Mitch Hardison
on Jul 6, 2010 at 1:24:38 pm
I am using 1.5.1 and I do not see a render setting. Hopefully they are set to camera settings by default. Thanks a lot
Walter Soyka
on Jul 6, 2010 at 1:32:19 pm
[Mitch Hardison] "I am using 1.5.1 and I do not see a render setting."
On Particular 1.5, it was called "Render mode." I don't remember what the default was.
Here's some documentation on depth of field with Trapcode 1.5. What I said before about particle type still applies; make sure that your particle type doesn't say "No DOF."
Walter Soyka
Mitch Hardison
on Jul 6, 2010 at 2:30:40 pm
Ok I found the setting. You are the man! Thank you so much
