How to do a go inside the monitor effect
Amri Aziz
on Jul 5, 2010 at 2:44:16 pm
Hello I would like to know how i could get a effect such as...i go on the table and go inside the monitor fitting myself in ?
Basically I wanna try to go inside a solid with you know those extremely light condition effect popping out with me going in.
Just for notice im a beginner so be a bit open thanks alot
Dave LaRonde
Re: How to do a go inside the monitor effect
on Jul 5, 2010 at 3:14:55 pm
Amri Aziz: "Just for notice im a beginner..."
As a beginner, you would not have known the following: it is almost impossible to learn a couple of tricks in After Effects, and have them work the way you think. AE is unlike any other video-friendly application you have used. It works completely differently.
If you ignore the basics and try to learn the techniques right away, you will have trouble, and you may even frustrate yourself to the point where you give up on After Effects. That's not good.
But there are sources to learn those essential basics, and here's one of the best. It's from Adobe's own After Effects Doumentation Guy, Todd Kopriva:
http://blogs.adobe.com/toddkopriva/2010/01/getting-started-with-after-eff.h...
Read EVERYTHING, and make sure to visit the links Todd provides.
Dave LaRonde
Sr. Promotion Producer
