out of memory
Robert Desiderio
out of memory
on Jun 30, 2010 at 2:23:57 pm
ok why is my duel Quad 24 gig ram saying OUT OF MEMORY for the first time in a while im working on a 3 min movie whats the deal i have tried IT ALL...... DES and can i upgrade to cs5 from 6
pss im on cs4
Kevin Camp
Re: out of memory
on Jun 30, 2010 at 4:06:51 pm
it's quite possible (even probable) that cs5 would fix this issue. being 64-bit, one instance of ae could address all 24gb of ram, but that doesn't help you much right now...
it would be helpful to know you multiprocessing and memory settings.
with 8 cores and 24gb, i'd try something like enabling multiprocessing, leaving 2gb for other processes, 4 cores for other processes and leave the faster render-longer previews slider in the middle.
if that still causes problems, disable multiprocessing and leave 4gb for other processes.
also, only have ae running during rendering (you could have task manager or activity monitor running to see how things are processing).
Kevin Camp
Senior Designer
Sebastien PANCRAZI
Re: out of memory
on Jul 16, 2010 at 2:17:53 pm
i had the same problem with a AE projet from pc 64 bit CS4 rendered on a mac 10.5 CS4 (32BIT) with 28 GIGA RAM
Try cmd+alt+shift when you lauch AE
i will reset the pref
5 sec in 10hours
good luck
© 2018 All Rights Reserved
