Break in image sequence
Lisa Simonson
on Jun 24, 2010 at 1:25:09 am
Argh!!
There is an extra 0 in the numbers of second render to tiff sequence ( computer crashed so i had to start over )I can open all the images separately in photoshop and some show up in my AE project but other than that, most frames read only as color bars in the comp.
Double argh!
Does anyone know a way to fix this?
Lisa Simonson
Re: Break in image sequence
on Jun 24, 2010 at 1:28:50 am
Do I have to take out the extra "0" in all 1300 frames?
Dave LaRonde
on Jun 27, 2010 at 6:01:48 pm
"Do I have to take out the extra "0" in all 1300 frames?"
You might: AE can work with 5-digit numbers for image sequences, but not 6-digit numbers. I hope you can find a renaming application that can remove leading zeroes.
Dave LaRonde
Sr. Promotion Producer
Joseph Pole
on Jun 28, 2010 at 7:35:08 am
It is fairly straightforward to do a batch rename and remove the extra zeros if you have adobe bridge (or any other app with batch rename)
in bridge navigate to your render, select the files with the superfluous zeros, then navigate to Tools/Batch Rename. That'll open up a window with a very clear batch rename interface.
*you might want to copy a portion of your render into another directory and do a test first.
http://www.josephpole.com
Lisa Simonson
on Jun 30, 2010 at 8:56:04 pm
Thanks for the seriously helpful info! Will definitely use in the future.
Manually deleted all the extra zeros before I got this tip. Ikes!
