3D precomp question. What?
Kevin Reiner
on Jun 23, 2010 at 2:16:56 pm
Hey all,
Trying to brainstorm the best way to do the following.
I have a grid of video squares (all the rage these days). The squares are precomps containing a 3D environment of living rooms with people doing typical things. All stills set up at varying degrees of Z-depth to show perspective change when the camera moves.
I want the camera to fly into one of these squares, but without a change in perspective until the camera almost fills the screen with the video square. At a certain point I want it to start paying attention to perspective, but not until we get really close. Hope I am explaining this well enough.
It is kind of similar to the Carnivale opening:
I am guessing that I need to cut between a collapsed and an uncollapsed version of my precomp? Maybe? Any suggestions would be much appreciated.
Kevin
System Setup (for a more detailed list, see my profile)
HARDWARE
Mac Pro 2 x 3 GHz Quad-Core Intel Xeon
9GB Memory
Two 16x SuperDrives
Dual-channel 2Gb Fibre Channel PCI Express card
Apple Cinema HD Display (23" flat panel)
ATI Radeon X1900 XT Graphics Card
AJA Kona LHe SD/HD capture card
Apple Xserve Raid 5.6TB
SOFTWARE
Mac OS X 10.4.11
Final Cut Pro Studio 2
After Effects CS3
Photoshop CS3
Illustrator CS3
Boris Continuum 5
Sapphire Plug Ins
Roxio Toast
Digital Anarchy Anarchist Suite
ParticleIllusion 3.0
Trapcode
Zaxwerks
Tudor "Ted" Jelescu
Re: 3D precomp question. What?
on Jun 23, 2010 at 6:34:01 pm
If what you're trying to do is just like in the example you posted, then treat your moves as separate comps and match the in and out frames.
One comp for the camera moves outside the pictures, all the way to when you get close enough that one image fills the frame- then you have a second comp with the image decomposed in 3D space, and a new camera move in the images space, and so on.
From my experience that's the easiest way to manage the moves and details. At the end you can render the segments and bring them in rendered in a final editing comp (or edit them in FCP or Premiere), or bring in all the comps in a master comp and render all out.
Tudor "Ted" Jelescu
Senior VFX Artist
Bucharest, Romania
http://www.ennstudio.ro
Kevin Reiner
on Jun 23, 2010 at 6:50:03 pm
Thanks Ted,
I did almost exactly as you described and it came out well.
I've attached an initial test.
http://reels.creativecow.net/film/flying-box-test
HARDWARE
9GB Memory
Two 16x SuperDrives
SOFTWARE
Mac OS X 10.4.11
After Effects CS3
Photoshop CS3
Illustrator CS3
Boris Continuum 5
Sapphire Plug Ins
Roxio Toast
Trapcode
Zaxwerks
