loop in AND loop out
Marc De Coster
on Jun 22, 2010 at 9:50:42 am
Hi! New problem ...
I have a project where some layers rotate around a globe (it's not for me, it's for a training session I give!)
and here is my problem: I wrote an expression to loop my rotation loop_out("cycle",0) and, of course, it works. Now, I wanted to have the same rotation withe a loop in. So I added a line to my expression:
loop_in("cycle",0)
loop_out("cycle",0)
and it doesn't work. I have a loop in OR a loop out but I can't have them both on the same layer. May be I should add something between my two expressions?
Any ideas?
Thank u guys
Michael Szalapski
Re: loop in AND loop out
on Jun 22, 2010 at 1:22:40 pm
You need ; after each line of code.
- The Great Szalam
Kevin Camp
on Jun 22, 2010 at 1:44:40 pm
what's happening is the last statement is the one that ae will execute. so, loop_out is the only one you will see.
what you'll need are some conditional statements that will make each statement get executed when certain criteria is met -- essentially, when time is less than when the rotation starts, loopIn; when it is after rotation ends, loopOut; if it is in between the keys, return the actual values...
something like this should work:
if (time=key(numKeys).time){
value;
}else{
if (timekey(numKeys).time) loopOut();
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Kevin Camp
on Jun 22, 2010 at 1:59:27 pm
oops, part of the expression was removed due to the symbols...
lets try this again:
if (time < key(1).time) loopIn();
if (time >= key(1).time && time <= key(numKeys).time) value;
if (time > key(numKeys).time) loopOut();
that looks better, and it's a little simpler than the original
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Marc De Coster
on Jun 22, 2010 at 2:11:49 pm
Yessss it works!
Thank u. I thought it would have been easier but ... expressions are always a pain in the ....
However, I wouldn't have find it by myself so ... thank u
Richard Thompson
on Aug 21, 2012 at 10:55:26 pm
Kevin that expression work is formidable. Really good stuff.
whilst messing around with the expression to understand how it works I found you can reduce your code slightly into this...
if (time < key(1).time) loopIn("continue");
else (value);
if (time > key(numKeys).time) loopOut("continue");
