Jagged diagonal lines
Marc Thomas
on Jun 21, 2010 at 10:27:15 pm
Hi, I'm working on D1/DV NTSC (o.9), 29.97 fps footage.
From what I understand, AE de-interlaces my footage automatically... then I get aliasing (jagged lines) on diagonal lines.
So my mission today was to find out how to avoid this "jagged line" problem.
1) Is there a way to do this? What settings do I need to set?
2) During my tests, I was exporting frames to compare my results and I got a BEAUTIFUL frame (ZERO jagged lines) that I exported after changing my composition settings to the "NTSC D1 Square Pixel" preset. But I was unable to duplicate my results. So I have no idea what else I changed besides the aspect ratio
Any help/insight would be much appreciated :)
Thanks in advance,
Marc Thomas
Re: Jagged diagonal lines
on Jun 22, 2010 at 5:23:04 am
I figured out that the exported frame with no jagged edges was produced by selecting "field render" >lower field first.
So, is this what I'm supposed to do when I have interlaced footage that I want to export?...
field render when exporting?
If this is the case, I'm very surprised I haven't read about this before as it seems like a pretty important piece of information.
© 2018 All Rights Reserved
