Render Queue optimal settings for HD editing?
Nikos Mamalos
on Jun 18, 2010 at 10:40:45 am
I would appreciate any help on the following
I need my final video to be in 1920*1080p for a final product either in Blu-ray or film
transfer facility.
I use AE and premiere CS4 or 5 on Macbook pro 2.6
  • With what sequence properties should I begin with in AE (a custom square pixel 1920*1080 25fps or an HDV 1440*1080)?
  • What are the optimal settings in AE Render Queue so that I could edit in real time in Premiere without initial rendering (without a red bar in timeline)
    Thanks a lot!
    Dave LaRonde
    Re: Render Queue optimal settings for HD editing?
    on Jun 18, 2010 at 3:14:09 pm
    If you intend to do a film-out, why would you work in a 25fps comp? Film is 24 fps.
    When using video cameras for film work, one normally shoots 24p. When any 3:2 pulldown is removed from the footage, the frame rate is 23.976 frames/sec, also known as 23.98.
    Film facilities know how to deal with a 23.976 frame rate when transferring to film.
    Dave LaRonde
    Sr. Promotion Producer
    Nikos Mamalos
    on Jun 19, 2010 at 3:04:14 am
    First of all thank for your response. 25fps is because I am in a PAL area (Greece). Film transfer facilities I have contacted will equally accept both 24 and 25fps. Also not all of our cameras shoot 24fps. With the above said, do you have any suggestions for the other issues?
    Thanks again
    NM
    Nikos Mamalos
    on Jun 24, 2010 at 9:13:54 am
    Some questions are doomed to remain unanswered!
