Tying particle emitter to individual letters of animated text
Nathan Manley
on Jun 17, 2010 at 10:32:11 pm
Hey all and thanks for reading.
I'm trying to achieve an effect with tying an instance of particular to each letter of an animated text layer. The letters all float in from different points and join together to form a word. I would like to have particle effects coming from each letter...what would the best way to tie the location of the emitter to each letter? Any thoughts?
Dave LaRonde
Re: Tying particle emitter to individual letters of animated text
on Jun 17, 2010 at 10:38:36 pm
I used to have Particular but sadly, I don't any more. So the memory has grown dim. Isn't there a way to use a Luma Map for an emitter? Then you could animate your letters using Stroke only, and get little sparklies or whatever you want.
Dave LaRonde
Sr. Promotion Producer
Nathan Manley
on Jun 17, 2010 at 11:00:03 pm
Hmmm, I will look into that Dave. The effect I'm going for is bubbles coming off of the letters. The animation is short enough that i can just track each letter by hand for each instance of particular, of course then I will have to redo it if I change the animation.
Nathan Manley
on Jun 18, 2010 at 12:35:50 am
Ah, sorry wasn't thinking.... set the particle emitter to layer with the text in a comp as the layer.
