XML import error
Dustin Ward
XML import error
on Jun 16, 2010 at 4:30:27 pm
I cannot import my XML into After Effects. I have done this before... I don't understand.
I got this message:
After Effects: AEGP Plugin Boris XML Transfer:
Cannot import this file with the Final Cut XML Importer.
Dustin Ward
Re: XML import error
on Jun 16, 2010 at 4:55:41 pm
apparently you have to right click and select "Final Cut XML via Boris XML Trnasfer". You can't just drag it in or use command I.
