Shaking in transition and still
Girshon Rutstein
on Jun 16, 2010 at 12:25:59 am
I created video with dissolve transition and 3 sec still at the end in FCP6. When I render these 10 sec clips in after effects HD 1920X1280 I see vibration or shaking in the transition are and in the still.
I tried to deinterlace the ending freeze frame it did not help.
What can cause this effect?
Girshon R
Kevin Knutson
Re: Shaking in transition and still
on Jun 16, 2010 at 8:23:51 pm
How are you rendering in AE? Are you rendering lossless? Which codec, etc?
How about composition settings? Do they match the footage you brought in from FCP?
Girshon Rutstein
on Jun 16, 2010 at 8:56:07 pm
FCP export self contain 1080i60, AE Pro res 422. 1920x1280 I did not know that it should match. I never had to, in the past. I would like to correct myself, its jitter horizontally, not shaking
Girshon R
Kevin Knutson
on Jun 16, 2010 at 9:13:22 pm
And just to clarify, is the problem showing after a full render from AE, in a video file, or is this happening during a RAM preview inside of AE?
Girshon Rutstein
on Jun 16, 2010 at 9:31:00 pm
After the final render
Girshon R
