Audio assistants
Kevin Mahon
Audio assistants
on Jun 9, 2010 at 3:06:28 am
Dear Forum
I need help with the audio, Everytime i make a video on after effects and i export the file there is no audio, its starting to get to me, it worked perfectly on cs4 but not on cs5, i work with quciktime movie files, is there any way that i can get the audio to work seeing as the audio is one of the key features to making a movie. im using cs5 on the mac with the lastest os. please anyone can help me
Todd Kopriva
Re: Audio assistants
on Jun 9, 2010 at 3:11:22 am
from After Effects Help:
"Note: Before rendering, check the Audio Output settings in the Output Module Settings dialog box to ensure that they are correct. To render audio, Audio Output must be selected."
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
Kevin Mahon
on Jun 9, 2010 at 3:20:46 am
ok so i did that and it still didnt work, i went to export to xfl file and it still doesnt work
Kevin Mahon
on Jun 9, 2010 at 3:27:27 am
still not working :(
Todd Kopriva
on Jun 9, 2010 at 3:59:35 am
I thought that you were exporting to QuickTime.
Audio isn't supported in XFL files.
"Audio is not exported to the XFL file."
Kevin Mahon
on Jun 9, 2010 at 4:08:28 am
with cs5 u have to export to xfl, its the only way
Todd Kopriva
on Jun 9, 2010 at 4:54:03 am
The only way to what?
Are you not aware of the render queue?
I get the sense that you need to begin from the beginning:
http://blogs.adobe.com/toddkopriva/2010/01/getting-started-with-after-eff.h...
