Imported clip
wren culp
Imported clip
on Jun 8, 2010 at 10:38:00 pm
I am messing around with AE for the first time and I stumbled upon a problem. Whenever I imported my clip to edit, it was zoomed in really far for some reason. I went down to the percentage and changed that around but it did not help. Any advice on how I can see the whole clip?
Bret Williams
Re: Imported clip
on Jun 9, 2010 at 5:45:57 am
When you place a clip in a composition, it is at 100%. That is, pixel for pixel. So if, for example, you put a HD clip in a SD comp, you're only going to see a small portion of the center of the clip. Press s to bring up scale. Then adjust the scale until it fits.
But perhaps you wish your composition to be the same size as the clip. Go to composition settings and choose a different preset, etc.
