wiggle expression time limited
Jared Eaton
on Jun 7, 2010 at 9:34:59 pm
Hi. I added a simple wiggle expression to a camera's position in AE CS4: wiggle(2,2) My question is what do or how do I add to the expression so that the wiggle only last for 3 seconds? I'm sure this is simple... Thanks in advance for your help.
Jared
Bob Root
Re: wiggle expression time limited
on Jun 7, 2010 at 10:39:01 pm
Here's a link from the Adobe documents that should help.....
http://livedocs.adobe.com/en_US/AfterEffects/8.0/help.html?content=WS22BD9B...
Jon Bagge
on Jun 7, 2010 at 11:23:23 pm
Alternatively add an expression control slider, and pick-whip from the wiggle amount to the slider. Then you can keyframe the amount of wiggle.
This will also allow you to fade up/down the wiggle amount rather than turning it on and off if that's any use to you. Use hold keyframes to avoid this.
Jon Bagge
Editor - London, UK
Avid - FCP - After Effects
Jared Eaton
on Jun 8, 2010 at 2:04:23 am
Thanks so much! This was very helpful!
