Exporting out alpha channel
kangling teo
on Jun 6, 2010 at 1:48:32 pm
Hey,
I've made a title sequence that I'm going to put onto live footage in FCP, so I exported out the sequence in alpha.
Problem is, when I export it out, the lens flare in my sequence is kind of screwed up and my text lost their colours.
Any ideas how to fix it?
Additional info:
Lens flare layers in Add transfer mode.
Used colorize from Hue/Sat for the colors on text/lens flare
Used animation compressor
Thanks in advance!
Tudor "Ted" Jelescu
Re: Exporting out alpha channel
on Jun 6, 2010 at 4:21:25 pm
Here's a great tutorial that will not only help you composite a lens flare, but give you some pointers on compositing in general:
http://library.creativecow.net/rollason_ben/lens-flare/1
Tudor "Ted" Jelescu
Senior VFX Artist
Bucharest, Romania
http://www.ennstudio.ro
Michael Lange
on Jun 6, 2010 at 9:04:57 pm
When you export with an alpha, make sure you set the alpha channel type correctly in FCP. Ctrl-click the clip in FCP and choose 'Item Properties' Set the alpha channel type to whatever is appropriate for your clip.
I would recommend exporting anything out of AE with a "straight alpha" since some other NLE, such as Avid, don't easily support premultiplied alpha channels.
Michael Lange
Producer/Editor
http://www.langetv.com/blog
