Plugin/Effect Animation Presets missing in CS5?
jack cook
on Jun 4, 2010 at 7:02:05 pm
Recently upgraded to CS5 and when applying an effect to a layer, where there were animation presets in older versions of AE, they are no longer. For example, in CS4, Fractal Noise had several "presets" displayed in a drop-down menu at the top of the Effect Controls panel (Blocks, Cinders, etc.), but it seems that in CS5, they are no longer available? This goes for third-party plugins as well, such as Particular. The presets exist on the hard drive, and can be accessed from Bridge, however this is a time-suck and can't be easily previewed. Anyone having the same problem, or some UI setting I'm missing?
Brian Charles
Re: Plugin/Effect Animation Presets missing in CS5?
on Jun 4, 2010 at 7:52:47 pm
In CS5 the default setting for the Effects Control panel is not to show presets.
Select it from the panel drop down and your'e good-to-go.
jack cook
on Jun 4, 2010 at 8:05:22 pm
THANK YOU!!! Seems weird that Adobe would turn this off by default, but I am happy to know that the option to turn it off is there, if needed.
Michael Szalapski
on Jun 4, 2010 at 8:47:12 pm
I prefer it off. I rarely, if ever, use presets so I just want the effects themselves to come up when I'm searching.
Adobe has had people request it both ways, I guess my side won :P
- The Great Szalam
Todd Kopriva
on Jun 5, 2010 at 1:39:04 am
BTW, this---like every single other change, no matter how small---is listed here:
http://help.adobe.com/en_US/aftereffects/cs/using/WS8269FE00-C552-478b-9204...
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
Eric Kirk
on Sep 24, 2011 at 2:43:27 pm
Boy, this was a big help. I can't count how many times I've run in to this and just accepted that the presets were no longer available!
Eric
Eric D. Kirk
http://www.kirkproductions.com
Stoney El-Abd
on Feb 7, 2012 at 2:23:56 pm
Yup, me too, just accepted that they were gone. Really dumb of me considering that the gillion presets I have slow my startup time by 3-5 minutes and I'm always dumping presets from the 'net into the presets folder in my sidebar.
Eric Kirk
on Feb 7, 2012 at 2:44:19 pm
Well, I sure hope you read the solution in the thread. Someone posted a picture of how to fix it. Wow, I wrote that a long time ago.
Eric
Eric D. Kirk
Stephan Nilson
on Apr 17, 2013 at 3:51:40 pm
OK. I'm having an issue that goes beyond just checking "Show Animated Presets." I have the option selected, but when I expand the Animated Preset drop down box there are no options. The Animated Presets are in the Effects and Preset window, but that's not giving me what I want when I want it. Here are two images to show what I'm referring to.
Thanks.
Stephan
Todd Kopriva
on Apr 17, 2013 at 6:53:13 pm
Stephan, have you saved any animation presets involving this effect? If not, what do you expect to see there?
After Effects team blog
