Custom Effects (PresetEffects.xml hacks) not working in CS5?
Lu Nelson
on May 27, 2010 at 2:36:56 pm
wondering if anyone's noticed this or if I missed some info somewhere about how to make it work in CS5; but Custom Effects that worked for me in CS4 now no longer function. Has something changed in the syntax? I tried just copying them from my PresetEffects.xml file in CS4 to the one in CS5, but everytime I launch a project that uses those effects it tells me they are missing...even though they appear in the Effect Controls pallette. They are all marked as "Missing: [Name]" where [Name] is the name of my effect.
Lu Nelson
Berlin, Germany
[MacProQ2.66, 8GB, Sys10.5.6, FCP 6.0.5, AE 9.0.2]
Lu Nelson
Re: Custom Effects (PresetEffects.xml hacks) not working in CS5?
on May 28, 2010 at 8:45:04 am
Looking further at this today, I tried installing a Custom Effect from Eran Stern using Maltaanon's PolyCE AIR installer application;
Install reports as being successful, but I get the same "Missing:" text in front of the effect name when I apply the animation preset. So it's not just my own CEs.
Something is broken with Custom Effects in CS5 I think...anyone else care to try this and compare?
Lu Nelson
Berlin, Germany
Rittgasser Istvan
on Dec 23, 2012 at 11:39:59 pm
Hi!
I had the same problem.
I'm not an expert, but this syntax works for me with CS5.5:
Effect matchname="Effect" name="Effect"
Group name="Group"
Checkbox name="Checkbox" default="false"/
Slider name="Slider" default="0" valid_min="0" valid_max="100" slider_min="0" slider_max="100"/
Angle name="Angle" default="0"/
Color name="Color" default_red="125" default_green="125" default_blue="125"/
Point name="Point" default_x="0" default_y="0"/
Layer name="Layer" default_self="true"/
Popup name="Popup" popup_string="Item1|Item2|Item3" default="1"/
/Group
/Effect
(Here I left the "less than", and "greather than" characters in the beginning and end of the lines, but they are needed - of course)
Maybe there is no other difference:
name= only once
and works the popup control
I hope it works for you too..
