Whip Pan Effect
David Bark
Whip Pan Effect
on May 27, 2010 at 12:19:55 am
Hi Guys,
So I'm going to try something that, for me, anyway, is a little advanced.
I'm going to create a little demo, with clips (smaller than the comp) playing inside of a frame. The clips will start right and slide left, doing a slow rotate on the y as the play. I'll have a background solid with a light ray effect or some such, and another overlay solid with some gently falling start or something (haven't figured out how to make that happen yet, but I will. Kind of like snow, but with little glowing stars. I wonder if I'll have to create each one individually? Whatever it takes.)
Anyway, at the conclusion of each clip, I want to whip pan to another clip in another frame. The background will blur, obviously, during the move. I guess my question is, how do I do that? lmao. I mean, do I make a ginormous background layer and pan the camera, or should I just have the next set of layers (background, clip in frame) waiting off to the side and slide it in real fast with some kind of transition?
Definitely willing to do some research - just finished watching a tute on creating a cube world, which was very cool but not what I needed, so even a nudge in the right direction will be appreciated. Could very well be I'm too big for my britches, being a relative newbie, but how else are you going to learn but jump right in.
I might even create a little reflection at the bottom of each clip, since all the cool kids are doing it!
Thanks.
David Bark
Lightshine Productions
Todd Kopriva
Re: Whip Pan Effect
on May 27, 2010 at 1:27:06 am
http://podcasts.creativecow.net/after-effects-tutorials-podcast/simulating-...
I found this with this search for the words in your subject line.
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
David Bark
Re: Whip Pan Effect
on May 27, 2010 at 3:00:59 am
Awesome. Thanks.
David Bark
Michael Szalapski
Re: Whip Pan Effect
on May 27, 2010 at 1:46:29 pm
And as for your slow falling stars, try a particle system. (CC Particle World, perhaps)
- The Great Szalam
Dave LaRonde
Re: Whip Pan Effect
on May 27, 2010 at 2:16:52 pm
There's a tutorial in the COW's tutorials section on how to fake swish pans...whip pans... whatever you want to call 'em. Carl Larson did it. You should look it up.
Dave LaRonde
Sr. Promotion Producer
adam taylor
Re: Whip Pan Effect
on May 28, 2010 at 7:48:10 am
Andrew Kramer at Videocopilot has a tutorial and some download plug-ins that would be of immense use for you on this project.
check out http://www.videocopilot.net/tutorials/
and search for Sure Target (he's done two tutorials as he's improved the plugin)
Adam Taylor
Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
Character Options Ltd
Oldham, UK
http://www.sculptedbliss.co.uk
