two videos playing interframe
luima morillo
on May 24, 2010 at 4:09:13 pm
Hello guys, im new here, my name is Luima, i am a 3d animator/modeler.
i am using after effects cs3, i want to merge two videos,they are frames secuences, one is called L001 etc, the other r001.etc about after effects, i want to merge them for stereoscopic output, i mean i want frameR01 then frameL01 then frameR02 then framel02 and so. is this possible with after effects?
thanks for your time on reading this
Chris Wright
Re: two videos playing interframe
on May 24, 2010 at 5:29:09 pm
a really easy way to do this is apply stylize strobe light to top layer
strobe duration 1/comp fps
strobe period 2/comp fps
strobe make layer transparent
interpret second layer fps / 2
now the top will show every other frame and the bottom will show each frame and not be skipped over
here's some more script tools you might find useful...
http://forums.creativecow.net/thread/268/145
http://technicolorsoftware.hostzi.com/
Chris Wright
on May 24, 2010 at 6:08:15 pm
interpret 1st layer fps / 2 too. This should use each frame without skipping either from each comp. I hope I understood you correctly.
