Mask on a Solid with Advanced Lightsning
David Bark
on May 23, 2010 at 7:53:05 pm
I can't seem to apply a mask on a solid layer with Advanced Lightning applied. I'd like to see the Lightning come out of the "clouds" rather than the top of the screen. I suppose I could move the origin point, but that would be a pretty harsh start. I'd like the lightning to emerge from behind a feathered mask.
The background is an AE file that sits behind everything. I've got four solid layers with Adv. Lightning applied. Applying a mask to those layers doesn't affect the lightning itself.
I could create a feathered shape layer that mimics the AI files "Clouds"/"Ground" but I'm wondering if there's a better way?
David Bark
Lightshine Productions
scott novasic
Re: Mask on a Solid with Advanced Lightsning
on May 24, 2010 at 6:42:55 am
simply pre-comp the advanced lightning layer... then all your bezier masking tools should work fine for feathering....
Animation & Visual Effects
Scott Novasic
Los Angeles Ca
© 2018 All Rights Reserved
