AE boggs down my machine real bad
Glen Jennings
on May 22, 2010 at 12:37:47 am
Is it me or does my Mac Book Pro, running 10.6.2 2.8 GHz Intel Core Duo with 4 GB ram, really get bogged down whenever I am using After Effects, and/or just playing Quicktimes on Quicktime Player.
Does anybody else notice this or have this problems? It's a disappointment because I got this new machine to run faster graphics and video and yet I have problems.
It really seems to choke the machine even when not rendering, I have trouble jumping to other apps like Safari or Quicktime Player.
Any insight or settings to make AE run faster?
cowcowcowcowcow
Seth Carleson
Re: AE boggs down my machine real bad
on May 22, 2010 at 1:09:46 am
I have 8 gigs of ram and also run into performance problems at times. I find that changing my magnification ratio helps things a bit (for instance rendering faster).
Doesn't surprise me though, some pro's have 32 gigs on their machine
Glen Jennings
on May 22, 2010 at 1:27:33 am
RE:changing my magnification ratio
forgive my ignorance but can you elaborate?
cowcowcowcowcow
Todd Kopriva
on May 22, 2010 at 3:12:16 am
There are a bunch of tips for improving performance here.
We can't really help you figure out what's going on without a lot more information, such as what version of After Effects you're using, what kind of footage you're using, and what your Memory & Multiprocessing preferences settings are.
4GB is not very much RAM for using After Effects.
You can _destroy_ your performance if you don't reserve ample memory and processors resources for other software. See these pages for some tips:
http://blogs.adobe.com/toddkopriva/2010/03/performance-tip-dont-oversched.h...
http://blogs.adobe.com/toddkopriva/2009/12/performance-tip-dont-starve-yo.h...
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
Bret Williams
on May 23, 2010 at 3:33:11 am
If you dont have multiprocessing on, AE is hard pressed to even use 2 gigs in my experience. I was running CS3 on 3 gigs alongside FCP editing 720p with no performance issues. A few page in/outs if I opened PS or Illustrator. I got 4 more gigs and AE doesnt use it unless i tell it to with multiprocessing.
In short, with 4 gigs- nothing should be bogging unless youve told multiprocessing to use all your cores and ram. Just turn it off with less than 6 gigs. If thats not it check and make sure your ram is actually seen by the system.
