Keying Question.
Craig Russell
Keying Question.
on May 20, 2010 at 7:00:12 pm
Hello, This may be a simple question but I am hopign someone can help. What is the easiest way to key a layer based on the colors in another layer? Does that make sense? :)
Thanks,Craig
Dave LaRonde
Re: Keying Question.
on May 20, 2010 at 7:15:53 pm
You can eyedropper the second layer's color when you select the key color.
Dave LaRonde
Sr. Promotion Producer
Craig Russell
on May 20, 2010 at 7:36:26 pm
Hi Dave - I attempted that however it is no responding. I have tried multiple key effects. ANy other ideas? Is there any other way to reference the object to key from beneath it?
Dave LaRonde
on May 20, 2010 at 7:52:56 pm
Tear off a tab? Make a solid the color in question? Take a flippin' screen shot? C'mon, get inventive, willya?
Dave LaRonde
Craig Russell
on May 20, 2010 at 8:16:03 pm
Apologies. I'm trying. Maybe this image helps?
http://www.hybrid7.com/help.jpg
Todd Kopriva
on May 20, 2010 at 9:27:36 pm
Create the transparency in layer 2 (the one with the head)---using keying effects, masking, Roto Brush, or whatever. Set that layer as a track matte (alpha matte) for layer 1.
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
Dave LaRonde
on May 20, 2010 at 9:47:19 pm
...and in addition to what Todd says, I wouldn't expect to do any keying, if I were you.
That's guy's against a light blue background. Frankly, it stinks for keying. Oh, you can give it a shot, but after you throw your hands up in frustration, you can start making a mask around that head.
If the head happens to move, you'll have to animate the mask... a process known as "rotoscoping".
Dave LaRonde
