can I render in a PC using 3th part plugins for mac?
Gerardo Flores
on May 3, 2010 at 1:25:26 pm
Hi I know that maybe is a stupid question,
but I just want to know if some of you have any solution?
What is more demanding for rendering RAM or CPU
and how I can improve the CPU of my MAC
best regards
Thats my real name :)
cowcowcowcowcow
Kevin Camp
Re: can I render in a PC using 3th part plugins for mac?
on May 3, 2010 at 2:56:34 pm
you would need the windows equivelent plugins (most developers make mac and pc versions of their effects).
as for performance benefits, cpu is most important (both speed and number of cpus/cores). ram can help, esspecially if it allows you to use more cores for rendering - the genereral rule is 2-4gb per core, so you can do the math for your system. with cs5, ae can use even more ram than that.
as far as upgrading the cpu, some macs do have socketed cpus that can be upgraded. you would need to search the web to see if yours is one of those, and the process involved to upgrade it. you might also weigh the option of selling your current system and getting a faster one.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Gerardo Flores
on May 3, 2010 at 6:25:20 pm
thank you a lot
G.
Gerardo Flores
on May 10, 2010 at 12:39:07 am
actually NOT
if you are using noise indrustries effects you can NOT
render in any other PC just MAC
learning after effects
