Mask Shape/Path in AE 7.0
Matthew Goldfinch
on May 1, 2010 at 3:08:41 pm
Before helping me, I would suggest someone watch the tutorial I am trying so they understand better. I am using After Effects 7.0, and I am trying to follow Andrew Kramer's "104. Shatterize" tutorial here >
I am upto the part about adding a mask to the text, I presume he is ussing AE CS5 or CS4. He is key-framing the Mask Path, while I only have Mask Shape. Later on you have to remove the key-frames of the Mask Path so that the text is cut up into 12 different sections. But when I go to remove the key-frames of the Mask Shape, I end up with 12 masks in the same top position. I didnt explain this very well, I am sorry.
-Matt G
Todd Kopriva
Re: Mask Shape/Path in AE 7.0
on May 1, 2010 at 4:19:49 pm
The name changed from 'Mask Shape' to 'Mask Path'. They're the same thing.
There's detailed information here about animating mask paths.
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
© 2018 All Rights Reserved
