After Effects Motion Tracking from outside of frame.
steve dann
on Apr 30, 2010 at 11:07:19 pm
Is it possible to motion track something that enters or leaves frame? The moment the search box hits the edge of frame it - unsurprisingly - freaks out. Haven't found anything about this anywhere. Any help much apreciated.
Kevin Camp
Re: After Effects Motion Tracking from outside of frame.
on May 1, 2010 at 1:23:30 am
mocha is a tracker that can track a point if it leaves the frame, however, you will need to be tracking multiple points that form a plane for it to work. this tutorial shows how that works.
http://library.creativecow.net/articles/rabinowitz_aharon/Mocha_Tut_1.php
or you may be able to track a second point after the first leaves the frame, then combine those tracks. video copilot has several tutorials where andrew uses this technique... here's one.
http://library.creativecow.net/articles/kramer_andrew/Set_Extensions.php
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Roland R. Kahlenberg
on May 1, 2010 at 7:17:02 am
The proper term is Offset Tracking. And you don't need seperate trackers. Perform a COW Search and there should be ample info for you in the AE forum as well as AE and Mocha tracking tutorials.
HTH
RoRK
Sell your AEPs with broadcastGEMs' DVD series of templates. Click here for more
steve dann
on May 1, 2010 at 8:45:42 am
Thank you guys, as long as the information is out there somewhere I'll find it. Offset tracking sounds like a good idea. I can't help thinking I saw a video tutorial a year ago that dealt with this but involved expressions.
on May 1, 2010 at 12:49:03 pm
That's Eran's COW Tutorial. The expression Eran used involves the Continue method. It's a good technique if there is no object within the shot for you to apply Offset Tracking.
Cheers
RoRK
steve dann
on May 1, 2010 at 5:16:40 pm
I'll look that up. Many thanks. What I'm trying to do is corner pin some thing (say an advertising hoarding) as it enters and leaves frame.
steve dann
on May 1, 2010 at 9:11:31 am
What I really meant to say was THANK YOU !!!!! I looked on Andrew Kramer's site but didn't know 'set extension' was what I needed to learn. That's the BEST video tutorial for AE I've EVER seen. THANK YOU for pointing it out to me.
