exposure
Matthew Wheeler
exposure
on Apr 27, 2010 at 10:52:53 am
I have a comp with a mask, some sky and the original foreground. Is there a quick filter i can apply that would adjust the brightness/exposure of the foreground comp using the background as source. I need to give the effect of the shutter closing down when the sky gets bright.
thanks
Walter Soyka
Re: exposure
on Apr 27, 2010 at 8:56:29 pm
I'd think the fastest way to do it would be to use the Exposure filter and keyframe it manually.
If you really need to do this automatically, I think you'll have to write an expression using sampleImage(). As always, Dan Ebberts has a great example of using sampleImage() to drive obscuration, and Todd Kopriva also has a quick write-up on sampleImage().
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Matthew Wheeler
Re: exposure
on Apr 28, 2010 at 9:08:20 am
Walter,
Thought that might be the case. I'll be sure to check out Dan Ebberts expressions, after ive met this deadline :)
I'm quite surprised there isn't a plug in for auto global exposure adjustment layer effect based on a given source layer.
Walter Soyka
Re: exposure
on Apr 28, 2010 at 1:09:39 pm
[Matthew Wheeler] "I'm quite surprised there isn't a plug in for auto global exposure adjustment layer effect based on a given source layer. "
There are effects that do the opposite -- like Color Stabilizer, which samples a reference frame and tries to make all other frames match it.
Walter Soyka
