After CS4 does not recognize all memory RAM
Arnaldo Alves
on Apr 22, 2010 at 10:16:04 pm
Hello I'm com one pc com 8gb memory RAM but when I start it shows that only after identifying this 4gb. I have to do?
I await aid
Thank you very much
Dave LaRonde
Re: After CS4 does not recognize all memory RAM
on Apr 22, 2010 at 10:23:51 pm
[Arnaldo Alves] "I have to do? "
You have to get a 64-bit operating system like Windows 7.
Dave LaRonde
Sr. Promotion Producer
Arnaldo Alves
on Apr 22, 2010 at 10:44:05 pm
Dave I'm using xp 64.Still does not recognize
Walter Soyka
on Apr 23, 2010 at 12:08:34 am
After Effects CS4 is a 32-bit application; each instance of AE can only see 4GB of RAM. To use more of your system's RAM, you need to enable multiprocessing (which launches multiple copies of the After Effects renderer, each of which can address up to 4 GB of RAM). You need 2 to 4 GB of RAM per instance for multiprocessing to be effective.
CS5 is 64-bit only, so a single instance of AE CS5 could address all 8 GB of RAM -- but it won't run on XP64. It requires Vista 64 or Windows 7 64-bit edition.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
