how do i create a movie like this? See inside
Steven Monk
on Apr 19, 2010 at 9:13:43 am
hi
i have to create an internal for our agency video similar to this:
http://infosthetics.com/archives/2010/03/accusing_googles_business_practice...
does anyone know how i would go about making it? is it just a case of having a huge composition and moving a camera around to the separate parts?
cheers
Tudor "Ted" Jelescu
Re: how do i create a movie like this? See inside
on Apr 19, 2010 at 9:36:47 am
From the looks of it I would say that's exactly how they did it. Vector art, for resolution, would allow for a decent size composition (2k or less) where you would animate the elements according to your timing. Then change the comp size to whatever you need, add a camera and animate.
Tudor "Ted" Jelescu
Senior VFX Artist
Bucharest, Romania
http://www.ennstudio.ro
Steven Monk
on Apr 19, 2010 at 10:35:58 am
cool thanks
Jon Bagge
on Apr 21, 2010 at 9:22:25 am
The composition itself doesn't actually have to be particularly big. It can be whatever size you want to render out at.
Build up the different elements as subcomps with vector art from, say, Illustrator. Then you can focus on the small animations without having to work in what will be a very layer-heavy main comp.
In the big comp just scale the elements down so they fit, then move the camera in and out. You can use continuous rasterization to keep the quality sharp.
Apart from that it's just simple transformations. scaling, position, rotation and camera moves. There is just lots and lots and lots of them so it will take some time to make.
Jon Bagge
Editor - London, UK
Avid - FCP - After Effects
