Puppet Tool, constrain distance between pins?
Stuart Paciej
on Apr 15, 2010 at 11:34:55 pm
Hi I'm animating an illustrated psd chain using the puppet tool - when manipulating the points the chain obviously stretches when the distance changes between the pin points.
In short is there a way / expression / attaching the pins to to nulls method to constraining the distance between them?
Thanks in advance!
Chris Wright
Re: Puppet Tool, constrain distance between pins?
on Apr 16, 2010 at 12:59:20 am
1. paste in the puppet position to each new pin
N = thisComp.layer("Null 1");
fromWorld(N.toWorld(N.position));
2. a) then just do a simple master parenting null.
2. b) or set null position with delay code
http://www.motionscript.com/mastering-expressions/follow-the-leader.html
http://technicolorsoftware.hostzi.com/
